Power
A project log for sat.Send
sat.Send is a small device that allows you to send and receive messages and share your GPS location no matter where you are.
John GrantJohn Grant 08/18/2014 at 20:230 Comments
Power is an issue that still needs further thought. Ideally I want the sat.Send to be portable so it could be used in remote or emergency situations so this would require some kind of battery. Possible to use solar to recharge? I need to finalise the system power requirements and then I will finalise the power supply. In the meantime during prototyping power will be supplied via a desktop supply.
