System Requirements Draft 1
A project log for Open Source Analog Effects Pedal
A modular platform for developing and trading guitar (and other) audio effects. Focus on, but not limited to, pure analog signal path.
JoshJosh 08/18/2014 at 21:140 Comments
Using the list of pedals from the Survey, the system level requirements have been completed on a First Draft basis. There should be enough requirements now to define the majority of the system. The only requirements still lacking are the physical definition of the position of the bus and standoffs. These will have to be worked out in physical modeling.
Check out the current requirements here!
https://github.com/Smerfj/OSAEP/wiki/System-Requirements
