Completed cases!
A project log for Pokey Watch
A chromatic tuner for musical instruments in a pocket-watch form factor. Perfect for the classy musician.
dbtayldbtayl 01/22/2015 at 19:530 Comments
I got the cases' finishes cleaned up today, as well as hinge pins inserted. That turned out to be easier than anticipated, as I found a (hefty) paperclip of the correct diameter. All I had to do was cut a piece off of the appropriate length, flatten one end to make it stick in the hinge, and insert it.
Pictures of the results:
Now it's on to firmware and (back to) electronics.
