dns-liar1.luaCaptive portal script that complies with the present version of the Lua firmware. Please add the following line to the end of IuT_00.lua:dofile("dns-liar1.lua") to enable this functionality. lua - 1.89 kB - 05/18/2019 at 13:23 |
Functionality2.wmvThe stress test - serving two clients simultaneously. Please note that the client system's time is displayed.x-ms-wmv - 3.12 MB - 06/09/2017 at 15:38 |
Functionality1.wmvVideo showing operation of the IuT voltmeter for a single connected tablet. Please note that the page automatically reloads every 300 ms which can be seen from some flicker of the address bar.x-ms-wmv - 7.08 MB - 06/09/2017 at 15:36 |
reload.htmlHTML page with embedded Javascript that displays clients's time and self reloads every 300 ms. Used for testing before being added to the server code.HyperText Markup Language (HTML) - 445.00 bytes - 06/09/2017 at 12:17 |
init.luaA service code to delay starting the main file (IuT_00.lua) by 3 seconds, during which the user can abandon automatic execution by connecting pin 3 to groundlua - 444.00 bytes - 06/09/2017 at 12:17 |
IuT_00.luaMain code providing the functionality. Calls ads_module.lua first then invokes a local unencryted WiFi access point (IuT_volt) then serves the dynamic web page on 192.168.4.1lua - 1.59 kB - 06/09/2017 at 12:16 |
ads_module.luaLua script containing test code for the NodeMCU ADS1115 driverlua - 1.81 kB - 06/05/2017 at 13:52 |
ads_my.luaLua script containing the ADC driver and some test code for itlua - 4.20 kB - 06/05/2017 at 11:37 |
