Log two: The circuit is made
A project log for 4x4x6 Led Cube with Text Display
A monochromatic led cube capable of displaying text sent via a virtual serial port.
kid-iccurusKid Iccurus 08/19/2014 at 11:000 Comments
Nearly fnished soldering the circuit on perfboard. Resistors are hooked up to the arduino and then a ribbon cable. A Johnson counter and a Darlington transistor array are also attached together and then to the duino and ribbon cable. The cable then goes to the cube and is connected via female headers. Just a little more to do before I can test.
