Schlieren Pattern Generator companion app
A project log for PyFSPro - Python Frame Sequence Processor
Multi purpose realtime frame sequence and video processor for a wide range of applications (schlieren videography, astroimaging and more)
mark-dammer-mm0dqmMark Dammer MM0DQM 05/31/2017 at 11:330 Comments
I removed the schlieren pattern generator part from PyFSPro because Kivy can only handle a single window. However there is no need to worry! The Schlieren Pattern Generator is now a separate application that can be downloaded / cloned from GitHub: https://github.com/mark-orion/Schlieren_PG
Whats New:
