VKOS (v3.8 - 2016.12.20).7zImproved the overall layout of the source code and did some general housekeeping with the documentation supplements (gamepad tester, header generator, etc); The launcher is now simply "runVKOS.sh", which executes the new GUI front-end.This new front-end lists a "Program Editor", which is intended for setting up automation routines/scripts, but this has yet to be implemented anywhere in the system... The basic framework for such a system update is likely to be the next version, since this update was all about unifying and simplifying the source code and user-side parts of this system. I've debated over an eventual full windowed GUI, but the current needs of the project can still be comfortably contained within the curses UI. Perhaps a future version will implement a more complex windowed UI, but until that time, I will continue to use the curses approach until I deem it too much of a nuisance to keep up with the evolving capabilities of the system, as I am generally fond of the look. x-7z-compressed - 9.12 MB - 12/20/2016 at 09:47 |
VKOS_CC (v3.7 - 2016.12.05).zipUpdated source code to include GPL license info/output. Info can be triggered with command line arg "ABOUT".Zip Archive - 26.89 kB - 12/06/2016 at 04:20 |
VisualK-OS Control Center - Documentation (v1.1).pdfMinor update with typo corrections and a corrected linear diagram of the FBA board flow.Adobe Portable Document Format - 71.72 kB - 11/03/2016 at 07:29 |
VKOS_CC (v3.6 - 2016.10.24).zipFirst release of the control center source code.Zip Archive - 25.66 kB - 10/24/2016 at 08:27 |
Adobe Portable Document Format - 72.22 kB - 10/24/2016 at 08:27 |
JPEG Image - 1.21 MB - 02/25/2016 at 09:12 |
JPEG Image - 1.56 MB - 02/25/2016 at 09:12 |
MPEG-4 Video - 2.36 MB - 02/25/2016 at 09:12 |
JPEG Image - 1.41 MB - 02/25/2016 at 09:12 |
JPEG Image - 1.57 MB - 02/25/2016 at 09:11 |
JPEG Image - 1.52 MB - 02/25/2016 at 09:11 |
JPEG Image - 1.47 MB - 02/25/2016 at 09:11 |
JPEG Image - 939.05 kB - 02/25/2016 at 09:10 |
JPEG Image - 854.80 kB - 02/25/2016 at 09:10 |
JPEG Image - 467.26 kB - 02/25/2016 at 09:10 |
JPEG Image - 105.03 kB - 02/25/2016 at 09:10 |
JPEG Image - 65.95 kB - 02/25/2016 at 09:10 |
JPEG Image - 76.69 kB - 02/25/2016 at 09:09 |
JPEG Image - 82.29 kB - 02/25/2016 at 09:09 |
[2015.07.03] Single LED Lamp Demo.mp4Demo video of first RGB lamp, before the flood boards were constructed.MPEG-4 Video - 14.53 MB - 02/24/2016 at 08:53 |
