The original project was to cure powder coating for motor cores and stators, but the heater setup is the same as what is used for the filament extruder.
This project has evolved from many others. Project logs may not make sense, and the links to the side are for my reference. They are not necessarily the parts used in the toaster oven project.
Gotcha. Well I wish the best, keep at it
