Two Servo Setup
A project log for Open IR Tracking Module
Low Cost, Fast response time between IR camera and a microprocessor. This provides rapid real-time tracking capability.
eric-jacobEric Jacob 08/20/2014 at 16:190 Comments
I've expanded upon the existing setup to add 2 servos. The takes data from the Wii IR camera (short wave IR, like that in IR LED's, not body warmth which is long-wave). This can be used for a camera tracking system. A simple IR LED can be added to a target and the camera will follow the target. Very little computing power is needed.
