Power board ahoy!
A project log for Audio Cube
An Audio Cube (Dice) that can audibly signal which side it has landed on.
david-wattsDavid Watts • 06/02/2015 at 17:48•0 Comments
The power board has been populated and is actually working, a few problems with some bad soldering means that the soft latching button isn't working as it should.
