Adding the IR Sensor and IR LED
A project log for Voice-Controlled Universal Remote
This is a remote that can be used to control all types of devices using voice commands. It can be programmed on-the-fly for any device.
mikesoniatmikesoniat 08/12/2014 at 15:370 Comments
Now I'm ready to add the IR sensor, which will be used for learning mode; basically reading the IR codes from an existing remote control. I'll also add a pushbutton to switch modes between learning and command and a transistor circuit for the IR LED, which will send the IR codes to the device you're controlling.
Below, I have attached Fritzing images of the breadboard and schematic.
NOTE: The Fritzing library did not include the voice recognition board, so I used a breakout board with similar connections.
