Full ALU simulation on Pyrite
A project log for Volumetric Circuits!
A schematic editor for "3D discrete grid-aligned circuits" and building a 1-bit ALU
Anderson AntunesAnderson Antunes 08/20/2014 at 17:220 Comments
The ALU design is done, now is time to test it. I put the schematics into the simulator and after some debugging it was ready to run, the result was great, all worked as expected. The following gif shows the schematics and demonstrate the simulator modularity concept.
Here is the ALU performing some random operations:
