added per frame slicer context
08/16/2014 at 08:26 • 0 commentsthe rotary switch can now be used to select one in several frames. the frame count is limited to 2, but easily changed via macro definition.
128 Mbits SPI flash memory soldered
08/15/2014 at 21:46 • 0 commentsremoved the SDCARD slot and soldered a 128 Mbits SPI flash memory laying around. still no software support, TODO.
added rotary switch for frame selection
08/15/2014 at 21:44 • 0 commentsa 7 positions (actually 12, but 5 unused) rotary switch has been added, with software support. next step: use it to select a particular frame.
