Source
A project log for Paintball Marker Mount
A replacement handle for a paintball marker so you can easily mount it on vehicles, robots or turrets
nathan-grayNathan Gray 08/19/2014 at 00:450 Comments
Source code, released under GPL 2
 * Control for custom A5 electronic trigger
 * Uses I2C to store settings and operate, with a switch as fallback
 * ATTiny45
 * Copyright (C) 2013 Paint Race Inc.
 * Author Nathan Gray
 * Released 2014-08-18
 *  This program is free software; you can redistribute it and/or modify
 *   it under the terms of the GNU General Public License as published by
 *   the Free Software Foundation; either version 2 of the License, or
 *   (at your option) any later version.
 *   This program is distributed in the hope that it will be useful,
 *   but WITHOUT ANY WARRANTY; without even the implied warranty of
 *   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *   GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License along
 *  with this program; if not, write to the Free Software Foundation, Inc.,
 *  51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
// Use i2c for commands & settings
#include <TinyWireS.h>
// For storing settings
#include <EEPROM.h>
// Default I2C Slave address
#define I2C_SLAVE_ADDR 0x26
//#define I2C_SLAVE_ADDR B0100001
// i2c commands
#define CMD_SET_ADDR      0x01
#define CMD_SET_ON_TIME   0x02
#define CMD_SET_OFF_TIME  0x03
#define CMD_SAFE_ON       0x0A
#define CMD_SAFE_OFF      0x0B
#define CMD_FIRE          0x10
// a5_a5_status
#define STATUS_SAFE  0x00
#define STATUS_FIRE  0x0F
// Pin definitions
#define FIRE_PIN 4
#define MANUAL_PIN 3
#define INT_PIN 1
// Memory locations
#define I2C_ADDR        0
#define ON_TIME_ADDR    1
#define OFF_TIME_ADDR   2
// Some safe defaults. solenoid should be good for 10%
byte i2c_slave = I2C_SLAVE_ADDR;
int on_time = 10;
int off_time = 100;
byte a5_status = STATUS_FIRE;
void setup() {
  // Init pins
  pinMode(MANUAL_PIN, INPUT);
  digitalWrite(MANUAL_PIN, HIGH);
  pinMode(FIRE_PIN, OUTPUT);
  digitalWrite(FIRE_PIN, LOW);
  pinMode(INT_PIN, OUTPUT);
  digitalWrite(INT_PIN, HIGH);
  // Load settings, if there
  if(EEPROM.read(I2C_ADDR) != 0xFF) {
    i2c_slave = EEPROM.read(I2C_ADDR);
    on_time = EEPROM.read(ON_TIME_ADDR);
    // Off time should be at least 10x on time, but that could overflow a byte
    off_time = EEPROM.read(OFF_TIME_ADDR) * 10;
  TinyWireS.begin(i2c_slave);
  // Wait to let the big cap charge
  delay(500);
void loop() {
  if(digitalRead(MANUAL_PIN) == LOW) {
    fire();
  byte byteRcvd,i = 0;
  int in = 0;
  if (TinyWireS.available() > 0){           // got I2C input!
    byteRcvd = TinyWireS.receive();     // get the byte from master
    switch(byteRcvd) {
    case CMD_SET_ADDR:
      if(byteRcvd >= I2C_SLAVE_ADDR && byteRcvd <= I2C_SLAVE_ADDR + 1) {
        EEPROM.write(I2C_ADDR, i2c_slave);
        TinyWireS.send(i2c_slave);
        // Need to reset now...
      break;
    case CMD_SET_ON_TIME:
      on_time = TinyWireS.receive();
      EEPROM.write(ON_TIME_ADDR, on_time);
      TinyWireS.send(on_time);
      break;
    case CMD_SET_OFF_TIME:
      in = TinyWireS.receive();
      in |= (TinyWireS.receive() << 8);
      if(in > on_time * 100) {
        off_time = in;
      else {
        off_time = on_time * 100;
        delay(50);
        digitalWrite(INT_PIN, LOW);
      EEPROM.write(OFF_TIME_ADDR, off_time);
      TinyWireS.send(off_time);
      break;
    case CMD_SAFE_OFF:
      //blinky(3);
      break;
    case CMD_SAFE_ON:
      a5_status = STATUS_SAFE;
      break;
    case CMD_FIRE:
      fire();
      break;
  digitalWrite(INT_PIN, a5_status == STATUS_SAFE ? HIGH : LOW);
// Debug
void blinky(int times) {
  for(int i = 0; i < times * 2; i++){
    digitalWrite(INT_PIN, i % 2 == 1 ? HIGH : LOW);
    delay(100);
void fire() {
  if(a5_status == STATUS_SAFE) return;
  digitalWrite(FIRE_PIN, HIGH);
  delay(on_time);
  delay(off_time);
