LM556 Dual Timer's Discontinued
A project log for GPS Dog Fence
Connected GPS Geofence Collar
erik-wachlinErik Wachlin 10/03/2017 at 19:561 Comment
Board Update
The LM556 dual timer is going to be discontinued, so I working on an updated circuit using the 555s and am going to integrate it into the PCB.  There will be an updated set of boards that I will be posting shortly.
Jarrett wrote 10/19/2017 at 22:03 point
There are enough different companies manufacturing this chip that it will never die. You can find other 556s on Digikey that will be identical, spec-wise
