Registers board (finally) arrived
A project log for JACA 1 & 2 Homebrew Computer
JACA - Just Another CPU Again Homebrew CPU, starting by a simple POC 4-bit CPU on circuit simulator soft. (done), then 8-bit (in progress)
Andre BaptistaAndre Baptista 05/02/2019 at 20:241 Comment
After a long wait the PCBs are finally home and as I started soldering the IC's sockets I noted a mistake on the very first: the 74HCT238 is DIP 16 and on the board are DIP 20... The IC footprint are pre configured on the EasyEDA but I have the fault of not revising one by one...
Well, life goes on and no way to wait another 6 weeks and spend more US$ 40, so I will make a ugly workaround to solve this.
Thanks for reading.
Yann Guidon / YGDES wrote 05/03/2019 at 11:11 point
I suppose there is enough room to make a small adapter PCB that plugs on the wrong footprint.
Good luck !
