Slow progress...
A project log for JACA 1 & 2 Homebrew Computer
JACA - Just Another CPU Again Homebrew CPU, starting by a simple POC 4-bit CPU on circuit simulator soft. (done), then 8-bit (in progress)
andre-baptistaAndre Baptista 03/22/2018 at 12:010 Comments
Slow project progress last month...
But at least I managed to finish the EasyEDA documentation of the modules (pictures below).
The situation so far: I have all the modules (a very crude version of them) finished and working on breadboards. This weekend I will try to put them together and hopefully see the CPU working for the first time outside the Logisim simulator.
By "working" I mean, capable of run one single instruction: LD A, value. That is, to load an 8 bit value in the A register (the only one avaliable).
After that, I could expand the modules, by adding registers, adding logic to connect the ALU to registers, logic to control the jumps, etc.
Thanks for reading.
