Running an entire program
A project log for JACA 1 & 2 Homebrew Computer
JACA - Just Another CPU Again Homebrew CPU, starting by a simple POC 4-bit CPU on circuit simulator soft. (done), then 8-bit (in progress)
andre-baptistaAndre Baptista 06/27/2019 at 21:470 Comments
I'm back again to the breadboard for this last module, as the work of soldering dozens of wires on the universal PCB was huge.
So I managed to make the PC and Memory module on a breadboard and run a simple program, with conditional and unconditional jumps:
The program loads the 32 value into A register and increments it until pass 255, then stops.
Thanks for reading.
