v.0.11.0 - Microcoded ROM
A project log for JACA 1 & 2 Homebrew Computer
JACA - Just Another CPU Again Homebrew CPU, starting by a simple POC 4-bit CPU on circuit simulator soft. (done), then 8-bit (in progress)
andre-baptistaAndre Baptista 07/10/2017 at 20:560 Comments
Finally upgraded from the archaic IC's of microcodes with combinatorial logic to ROM, still in Logisim.
In real hardware will be used 3 of the AT28C256 EEPROM in parallel. It's a huge waste of space, I know, but there aren't smaller chips, or the cost is almost the same.
PS. Now there is a LCD output, and a test program to print an 'A' char. All ready to make a classic Hello World program!
