SDR in a box
A simple box that will open airwaves for you
The box contains a full set of tolls that are necessary to build a radio transmitter or receiver, pack it in a bag and enjoy listening (or transmitting) far away from civilization. Implemented in a real hacker-style, using cardboard box and a bunch of zip-ties to put all components together. The cost of the entire system with only rtl-sdr receiver should be less than $200.
The box started as a prototype of a hardware for an interdisciplinary research project, which requires sensing of RF spectrum. Since the project is still in very early stage, I'd rather not discuss it, but instead I want to focus on the part that will be more useful for fellow hackers - a small and handy box, which contains everything what is necessary to build a portable digital radio.
  • 1 × bladeRF Radio transceiver
  • 1 × RTL dongle Radio receiver
  • 1 × ECS CDC-I/D2500(1.0) Intel Atom D2500 Intel NM10 Mini ITX Motherboard
  • 1 × Kingston DataTraveler 8GB flash drive Boot and data disk
  • 1 × Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter WiFi radio interface
View all 19 components
  • Sensing the RF
    piranha3208/21/2014 at 02:18 0 comments
    In my project I have to detect presence of short pulses sent by the transmitter. The detector must be robust, must be able to automatically adjust to changing signal and noise levels, and provide a mechanism for recording geographic coordinates of the location where the signal was detected. After quick scan of available GnuRadio modules I decided to implement the detection myself, because none of the existing modules was able to do the job.
  • Architecture of the box
    piranha3208/21/2014 at 01:16 0 comments
    My goal in building The Box was to have a universal and portable platform for experiments with software radio. The other goal was to only use components that I had at home. These two conditions shaped the overall hardware architecture of the system.
  • How to convince gpsd to talk to your GPS
    piranha3208/18/2014 at 06:09 0 comments
    gpsd is a wonderful tool. It allows many programs to talk to one GPS device, without problems with resource allocation conflicts. The library linked to user apps takes care of parsing all the information and outputs easy to digest numbers.
    As awesome as the software is, it has several disadvantages. The most annoying of them is how the program handles detection of  speed on serial port. The authors insist on not allowing to inform the daemon about bit rate and auto-detection not always works as it is supposed to work.
  • Using VirtualBox to install OS for an embedded system
    piranha3208/17/2014 at 23:19 0 comments
    Embedded systems are fun to play with, but installation of the OS can be a real pain. In my case the OS was not a big problem (I'm using a plain, old, boring PC hardware, after all), but as usual, the devil lurks in the details. In my case none of the monitors I have at home was able to display the video signal from the board (23" Dell LCD went just blank, while 17" LCD at least showed a message about unsupported video mode.) The only device that worked properly was a projector. Being a lazy brat as I am, I decided to not to stand at the projector holding the keyboard in one hand and the board in the other, and hack the entire process without touching the target board at all. Enter VirtualBox, a full PC system in a small window on the monitor.
  • Installation of WiFi antenna next to GPS antenna is a bad idea
    piranha3208/16/2014 at 19:01 0 comments
    First real test came. Battery charged, receiver antenna connected to bladeRF, application started, waiting for a GPS fix.
    5 minutes passed, still waiting for GPS fix.
    10 minutes passed, still waiting for GPS fix.
    What about unlugging the WiFi dongle?
    1 minute passed - GPS' got the fix!
    WiFi antenna has to be moved from top of the box to another spot, further away form the GPS.
View all 5 project logs
  • 1
    Step 1
    Since each build most likely will be different, giving exact building directions makes no sense. I will describe the most important steps during the build, however you will have to use to use own imagination and creativity.
  • 2
    Step 2
    Put all your components on a pile.
  • 3
    Step 3
    Find a suitable cardboard box.
View all 7 instructions
