The input buffer will be emptied after "enter" is pressed. Therefore, to support defining new words, the codes in input buffer need to be moved into user code area. The "interpreter" will interpret the codes in the user code area when new word is added.
Adding a new word has been implemented. Editing an old word is to be implemented.
Thumb2
