MVP - Solar Powered Smart Compost System
A project log for The Compost Professor - A Smart Composting System
A set of senors and actuators that make composting simple.
darian-johnsonDarian Johnson 08/14/2017 at 21:590 Comments
Aug 14 2017 -
It's been a busy few months since my last log. I've updated the solution as follows:
The good news is that I've tested the logic and feel comfortable with the analysis algorithm.
The bad (or good, depending on the point of view) is that the solution still requires work:
I'm in the process of making design changes, now. The goal is to have a more robust prototype available for testing by early September.
