Debugging over the network
A project log for Garage Door Sensor
Using the ESP8266 to broadcast open/close MQTT events over WiFi
andy-castilleAndy Castille 11/22/2017 at 19:221 Comment
I just posted a new version of the code that also provides a server so that you can check the current status while it is running remotely:
$ telnet 192.168.2.8
Trying 192.168.2.8...
Connected to 192.168.2.8.
Escape character is '^]'.
mqtt_connected = 1
distance_cm = 102
door_open = 1
Connection closed by foreign host.
paulfecht wrote 05/08/2022 at 20:16 point
Are you running this code from a command line or?
