SonoffDocumentation.pdfAn alternative board, implemented by @juan11perezAdobe Portable Document Format - 1.22 MB - 03/08/2018 at 21:46 |
GarageDoorSensor2.inoCompiles to both the ESP8266 (tested and working) and Arduino with WiFi shield (not tested).ino - 3.19 kB - 11/22/2017 at 19:27 |
Standard Tesselated Geometry - 233.09 kB - 05/30/2017 at 00:23 |
Standard Tesselated Geometry - 246.76 kB - 05/30/2017 at 00:23 |
CeilingMount.iptChange the Fan parameter to automatically modify the front of the model.- 596.00 kB - 05/30/2017 at 21:00 |
Layout.pdfContains external dimensions of the components used.Adobe Portable Document Format - 149.27 kB - 05/30/2017 at 00:25 |
Project.zipThis contains all of the files you need (which are on this page as well) and everything used to create them.application/x-zip-compressed - 17.54 MB - 06/05/2017 at 22:23 |
