Updates to the slider
A project log for ZBeam - Shape Shifting Structures For Space
Self-reconfiguring modular structural elements for space habitats
ronald-jaramilloRonald Jaramillo 06/17/2017 at 01:250 Comments
With the increased tightening of the chains, the existing slider became quite prone to jamming. To address this I needed to redesign the guide arms. I decided to add bearings as contact points. In order to get the placement of this points right I started by printing an adjustable set of linkages.
After som fidgeting and some trial and error, I was happy with an specify configuration. I redesigned the slider block with a set of (permanent) guiding elements.
Next, i began to work on the spool holder and gear transmission needed to roll the chains.
