Nixie Clock on ESP8266 module
Nixie Clock on ESP8266 module with synchronization with NTP server. Simple circuit.
This is my new project "Nixie clock on ESP8266". Here I used the decoder 74141 and the neon indicators IN-12. Features: 1) Powered by USB port. Low energy consumption. 2) Connects to the network wi-fi. 3) No time setting required. 4) Synchronization with NTP server. 5) Firmware update by air (OTA). The project uses dynamic indication and a simple step-up voltage converter up to 180V. Supply voltage 5V and current consumption about 200 mA.
License: Open Source Licensing
JPEG Image - 1.20 MB - 01/18/2020 at 08:59
Preview
retroCLOCK.ino
Firmware
- 9.39 kB - 06/12/2017 at 05:33
Download
Face panel for nixie clock .stl
For 3D printer. Face panel for nixie clock box.
Standard Tesselated Geometry - 43.64 kB - 05/30/2017 at 16:45
Download
box for nixie clock.stl
For 3D printer. Box for nixie clock.
Standard Tesselated Geometry - 6.92 kB - 05/30/2017 at 16:42
Download
pinout ESP8266
Portable Network Graphics (PNG) - 159.35 kB - 05/30/2017 at 16:39
Preview
  • 4 × IN-12 Nixie Tube
  • 1 × ESP8266-12F
  • 1 × 74141 Electronic Components / Misc. Electronic Components
  • 1 × LM1117-3.3 Power Management ICs / Linear Voltage Regulators and LDOs
  • 1 × TLP627 Opto and Fiber Optic Semiconductors and ICs / Optocouplers and Optoisolators
View all 7 components
  • Total board update 10.22.2017
    V.G.C. • 10/22/2017 at 17:12 • 0 comments
    Warning! Total board update 10.22.2017
    Changes:
    1. Simplified the scheme of high voltage control. Instead of transistors added high-voltage optocouplers (TLP627, you can use TPL627-4)
    2. Improved step-up converter voltage. Now it works more effectively.
View project log
  • 1
    Step 1
View all instructions
rockdomenik1105 wrote 05/29/2021 at 12:16 • point
How to get a detailed description with a diagram?
Cezary wrote 07/13/2018 at 06:52 • point
Hello. Great project, planning to build it soon. How difficult would be adding 2 lamps for seconds display from programming perspective?
rlb-designs wrote 07/17/2017 at 08:37 • point
Hi Just joint. how are you programming the ESP-12F? Are you using a USB/Serial convertor or a Arduino.
Thanks.
V.G.C. wrote 07/29/2017 at 08:07 • point
Hello! Yes, I used a USB/Serial converter first but then OTA update.
You are welcome.
rlb-designs wrote 08/02/2017 at 10:49 • point
Hi, Thanks I thought that's how your were doing it. I see your only driving 4 nixie's could you not add 2 more for the seconds instead of the LED's? By adding the additional transistors etc. from GPIO1 and GPIO0, would you need to mod the sketch too.
Regards
Robin.
Paul Andrews wrote 06/24/2017 at 04:50 • point
Is that really a 200mH inductor? Nothing that size on Digikey or Mouser.
Maksim Surguy wrote 07/11/2017 at 03:41 • point
@V.G.C. I have the same question as ^, could you specify the inductor specs or alternatives please?
V.G.C. wrote 07/29/2017 at 08:12 • point
I used to transformer from mobile charger as inductor. Used high voltage coil.
V.G.C. wrote 06/12/2017 at 04:19 • point
Hello! I used 2SC4706 and A733 transistor. 2SC4706 need connect to coil.
Maksim Surguy wrote 06/11/2017 at 15:54 • point
Hi! What transistors / FETs did you use in the step up voltage converter? The schematic is not saying about that so just wanted to check!
Thanks!
