Total board update 10.22.2017
A project log for Nixie Clock on ESP8266 module
Nixie Clock on ESP8266 module with synchronization with NTP server. Simple circuit.
vgcV.G.C. 10/22/2017 at 17:120 Comments
Warning! Total board update 10.22.2017
Changes:
1. Simplified the scheme of high voltage control. Instead of transistors added high-voltage optocouplers (TLP627, you can use TPL627-4)
2. Improved step-up converter voltage. Now it works more effectively.
