The Hat Version is Working
A project log for Single-cell Li-Ion Powered UPS for Raspberry Pi
A simple yet complete UPS solution for most Raspberry Pi embedded applications, using a single-cell Li-Ion Battery.
bud-bennettBud Bennett 07/22/2017 at 19:340 Comments
The Hat PCB is functioning as designed. Here's a photo of it attached to my Raspberry Pi 2 B.
I ran two discharge tests on this UPS version. The first was with the red Efest 700mAh battery: it lasted 1 hour 15 minutes. The UPS lasted 1 hour 51 minutes using the black KeepPower 800mAh battery. The load for both tests was an idling Raspberry Pi 2B.
The SOT23-5 battery charger gets quite hot when charging the battery with full current, but it doesn't appear to cause any problems since the charger has a thermal limit.
At this point I'm pretty much done with this project. I will let PaulV perform the 2-3A torture testing.
Here's a photo showing all three PCBs for comparison purposes.
