Firmware.zipVersion 1.0.34 of the firmware. Note that this version connects to the internet once per minute to publish a empty weight to track drift so needs modification for low power (battery) usage.x-zip-compressed - 35.56 kB - 06/10/2017 at 02:12 |
BottleBuddy-V1.1.schEagle schematic file for V1.1 PCBsch - 703.55 kB - 06/08/2017 at 03:25 |
BottleBuddy-V1.1.brdEagle board file for V1.1 PCBbrd - 127.35 kB - 06/08/2017 at 03:25 |
PCB-Top.pngPCB V1.1 Top (Everything except bottom copper)Portable Network Graphics (PNG) - 344.24 kB - 06/08/2017 at 03:24 |
PCB-Bottom.pngPCB V1.1 Bottom (Everything except top copper)Portable Network Graphics (PNG) - 330.34 kB - 06/08/2017 at 03:24 |
Schematic-V1.1.pngSchematic for the V1.1 design.Portable Network Graphics (PNG) - 287.76 kB - 06/08/2017 at 03:24 |
PrototypeBaseWithLoadCell.stl3D printable foot base for the protoytpe PCB with mount for a load cell and battery.Standard Tesselated Geometry - 2.01 MB - 06/08/2017 at 00:51 |
PrototypeBaseWithLoadCell.scadOpenSCAD version of the 3D printable foot base for the protoytpe PCB with mount for a load cell and battery.scad - 6.37 kB - 06/08/2017 at 00:50 |
LoadCellModel.scadModel used for the load cell to help allignmentscad - 2.18 kB - 06/07/2017 at 18:42 |
LoadCellModel.stlModel used for the load cell to help allignmentStandard Tesselated Geometry - 35.87 kB - 06/07/2017 at 18:42 |
BottleBuddyTop.stlTop half stl file for 3D PrintingStandard Tesselated Geometry - 6.55 MB - 06/07/2017 at 18:39 |
BottleBuddyBase.stlBottom half stl file for 3D PrintingStandard Tesselated Geometry - 5.39 MB - 06/07/2017 at 18:39 |
BottleBuddyTop.scadTop half openSCAD file to allow tweaking of designscad - 18.28 kB - 06/07/2017 at 18:38 |
BottleBuddyBase.scadBottom half openSCAD file to allow tweaking of designscad - 12.52 kB - 06/07/2017 at 18:38 |
