KickOff
A project log for TwinLight
TwinLights are RGB LED based lamps, driven by an ESP8266 using Blynk
pascal-roobrouckPascal Roobrouck 06/01/2017 at 09:540 Comments
Todo :
1. Ordering components : more NeoPixels, dot-matrix LEDs. (Wemos D1 Mini, Wood and Plexiglass are 'in stock')
2. Make CAD model in order to do the CNC milling and make sure everything will with fit together
3. Write Software - Using Visual Studio, Sorce-code will go on Github
