Mag lev lev lev mag,
Like and subscribe <a href="https://www.youtube.com/channel/UC2YO4wXHmpn9QgrHh7-0TXA/videos" target="_blank">https://www.youtube.com/channel/UC2YO4wXHmpn9QgrHh7-0TXA/videos</a>
For facebookers Turntable D.I.Y <a href="https://www.facebook.com/groups/1547870771921160/" target="_blank">https://www.facebook.com/groups/1547870771921160/</a>
Check out the other projects <a href="https://hackaday.io/neris" target="_blank">https://hackaday.io/neris</a> - Do not underestimate project Logs!
Related:
Sound Card: <a href="https://hackaday.io/project/19825-gintba-modular-sound-card" target="_blank">https://hackaday.io/project/19825-gintba-modular-sound-card</a>
Audio Effects: <a href="https://hackaday.io/project/25250-audio-fx-effects" target="_blank">https://hackaday.io/project/25250-audio-fx-effects</a>
How to piss of Australians by simply thanking them (leaving that group).. the abuse I get online.. I must say that Hackaday is the friendliest crowd (apart from some curators refusing to add some of the projects to specific collections)
Measuring range +/- 0.256V over 16 bit resolution @ 16x gain, with a 0.0078125mV per step. One could measure phono cartridge to see if there any magnetic fields present that could affect the sound quality (to get the voltage, multiply the value on the screen with this number, 4k video) Arduino and ADS1115
No, not yet, sorry if it gave you the wrong impression. While mechanical to optical works, as in DS Audio, I hear that pure optical sampling does not work well on transparent, coloured or picture vinyls.. Finding a specific laser/wavelength might work. On the other hand, playing the stampers in optical way should be quite easy as the surface is reflective/metalic. Will be making a log about it.
Oh I see, I think. You're using the alignment coils to read the position of the lens rather than set it? Or are you using a reflected light beam as an amplifier?
Either way, its a very cool bit of hacking. And that is a nice bit of soldering ;-)
If we are talking about https://hackaday.io/project/25198/log/60708-old-cd-rom-drive-blunt-sewing-needle-phono-cartridge log, the focusing lens is attached to the coils which freely moves along static/glued magnets, allowing to focus the laser. In this case, the action is reversed, where the needle moves the lens and the coils attached to it, effectively turning focusing motor into a moving coil cartridge aka MC.
If we are talking https://hackaday.io/project/25198/log/61795-youve-heard-it-here-first-leds-on-the-cartridge-lighting-up-the-groove log - it's just an idea of using LEDs directly on the cartridge, to illuminate the spacing grooves, making easier to locate the beginning of the chosen track. (Currently, as in the photo, (I only have one record @ the moment,) that does not contain spacing grooves to separate/distinguish between multiple tracks) Thanks for the compliments, always happy to answer questions ;)
Ahh so the LEDs are just for light, that threw me completely, I thought lights on DJ rigs would be a thing... I guess they are now :-D I'd also describe what you've done as not so much hacking vinyl, but hacking a CD player to play it. Which is delicious btw ;-)
I've seen a guitar tuner that works by flashing red and blue LEDs at the correct frequency on the string. The beat frequencies form distinct phase patterns on poorly tuned strings, and the object of the exercise is to get a parallel line on the string... I must get round to making one, its basically an Astable Oscillator lol. If you converted the audio to flashing colours, the tones used in the recording should be picked out visibly on the grooves as an interference pattern.
One thing sprang to mind regarding optical sampling. How about a high definition camera with some lensing and motor sync?
Thanks for interesting thoughts ;) Saw a video sometime ago, now I see people reproducing it with webcams too Getting the right shutter speed makes magic pictures
My fascination with lasers, optics, images, manipulation, post production, vfx, sound etc is never ending
On my todo list is vinyl flatbed scan on highest resolution possible Will try strobing guitar strings too, there are also patterns for turntable http://keystrobe.com/Discs.html :D
Oh wow, I have never seen the guitar strings done like that before. The tuner works at the same frequency as the string, and only illuminates a tiny bit... Arrgh, now I have to make the light-tuner bigger and add lower frequencies to it lol. Parametry rocks, it's literally what makes the universe tick... ;-) Great videos :-D
Funny you should should mention a microscope, a mate of mine gave me a jewellery inspection magnifier:
I had it apart out of interest, it contains two pairs of lenses with spacers and bushings that fit into round holes in the casing, it wouldnt take much to mount them end-to-end in a tube to get 180X with a webcam on the end of it, and the LEDs on the other... Although,
Most flatbed scanners use software interpolation to get up to 1200DPI as advertised, if you find a genuinely high res one it will not be cheap... :-( Great lateral thinking with the optical mouse though. Never played with the insides of one of those myself...
You're sampling the record optically? Groovey... :-)
