3] Hardware tests
A project log for USB TinyTracker
A USB-flash sized GSM/GPS tracker with a wide array of features
paulPaul 06/10/2017 at 00:240 Comments
So far, all routing and signals seem to be OK. Power (5V from USB) is not shorting anywhere and it seems that it should be safe to start working on programming the MCU.
