4] Programming begins
A project log for USB TinyTracker
A USB-flash sized GSM/GPS tracker with a wide array of features
paulPaul 06/11/2017 at 23:071 Comment
I have started working on the bootloader and testing a couple basic sketches.
slashdev wrote 06/14/2017 at 18:50 point
Be sure to check out NeoGPS: smaller, faster, more accurate and *totally* configurable to parse only the pieces you care about.  The `fix` data structure is convenient for making queues and logs of the parsed GPS information.  It is supported on most platforms.
