quick guide to securing the thing / recover password
A project log for DBPOWER ELM327 Wi-Fi Interface (OBD II) "review"
just out of interest I bought one of these to play with
rawerawe 08/28/2014 at 18:298 Comments
 cmd> setet 4
 Ok
 cmd> setwp *****************
 Ok
 cmd> setssid Bordnetz
 Ok
 cmd> wificonfig
 SSID  : Bordnetz
 Network Type: AP(2)
 Encrypt Type: WPA2-AES(4)
 PassPhrase  : *****************
 Ap's channel: 1
 Dhcp Client : enable
 Ok
 cmd> saveconfig
 Saving Configuration to FLASH
 Ok
 cmd> reboot
 device will reboot...
 Ok
 cmd>
and *tadaa*
Cell 06 - Address: 00:0E:C6:00:3B:1B
   Channel:1
   Frequency:2.412 GHz (Channel 1)
   Quality=48/70  Signal level=-62 dBm
   Encryption key:on
   ESSID:"Bordnetz"
   Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s
   18 Mb/s; 36 Mb/s; 54 Mb/s
   Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s
   Mode:Master
   Extra:tsf=00000000366ff4f2
   Extra: Last beacon: 344ms ago
   IE: IEEE 802.11i/WPA2 Version 1
   Group Cipher : CCMP
   Pairwise Ciphers (1) : CCMP
   Authentication Suites (1) : PSK
Serega wrote 11/18/2018 at 13:28 point
how reset  login  user password on
for OBD host: 192.168.0.10  ?
insename2 wrote 03/20/2017 at 04:11 point
Thanks for all the discovery and hacking. I am reading the instructions on how to secure the wifi and for the life of me I can't figure out what you mean by cutting the 5v trace. It looks like the CP2012 already has a 3.3V power out? Do I have to use a jumper and sever a trace to get 3.3 out of this board?
Also, my wifi module says Nufront on it but looks almost identical. Is it based on the same AXIX chipset?
Alexandru wrote 01/12/2016 at 06:59 point
is it possible to make the elm scan for an wifi network, if found connect (credentials saved in code), if not switch to ap mode
rawe wrote 01/13/2016 at 14:21 point
For this, you may want to replace the integrated wifi module with an ESP8266 and script this via LUA.
opelfahrer79 wrote 02/15/2015 at 12:59 point
Hey. Can you please provide an exact pin connection for accessing the wifi module with an Uart converter?
Given this one:
https://cdn.hackaday.io/images/4168131408466927600.jpg
is it in order 2,3,4,5 for GND,TX,RX,POWER?
rawe wrote 02/16/2015 at 11:52 point
You are right. See https://hackaday.io/project/2523/log/7428 for a pinout.
2 GND. 3 TX. 4 RX. 5 3.3V (not 5!). 38400 baud.
rawe wrote 02/17/2015 at 16:33 point
this board provides 3.3V singal levels but no 3.3V supply voltage. you could use something like LD1117V33 (from Conrad) plus two decoupling caps (100nF / 1uF), or a cp2012 based adapter (cp2012 contains 5V to 3.3V regulator, adapter boards are 1-3 eur at ebay, incl. shipping).
