LightBox - ambient backlight
LightBox is a PC-based real-time ambient lighting effect that attaches at the back of your home media PC theater or monitor
LightBox is a PC-based real-time ambient lighting effect that attaches at the back of your home media PC theater or monitor and creates a nifty light effect behind your screen. It's simple to set up and will definitely pop up your movies, games, shows or even regular work on your computer with an additional dimension.
Additional you can install LightBox in your car because it use 12V power supply.
More information are available on: https://www.indiegogo.com/projects/lightbox-ambient-backlight
How does LightBox work?
LightBox is a combination of hardware and software. Bits of software capture content at the edges of your screen in real-time, converting them to LED color data and sending them to modules which display specific color - the whole process happens so fast that our eye can not recognise it.
Two models of works
Static light is first of the lighting style. You can set different colors on each of LightBox channel ( LightBox have 10-channel ), that will be displayed each time you turn on the device. You can easily change color connecting LightBox to computer using USB and set new color in software. Sample of use static light in LightBox :
  • TV static backlighting ,
  • car backlight,
  • PC static backlight,
  • backlight in room, kitchen or bedroom,
  • furniture backlighting .
Dynamic light, this is the main function of LightBox, it creates light effects around the television that correspond to the video content. LightBox is a lighting system that actively adjusts both brightness and color based upon picture content. This technology is aimed to enable the viewer to see more picture detail, contrast and color while eliminating on-screen reflections. Sample of use dynamic light in LightBox :
  • watching dvd movie,
  • playing pc game,
  • watching pictures.
  • 1 × LightBox driver
  • 1 × 12V power supply
  • 10 × Led cables
  • 5 × Cable ties
  • 1 × USB cable Electronic Components / Misc. Electronic Components
View project log
