HiGrow plants monitoring sensor
soil moisture, humidity and temperature for monitoring your plants
HiGrow is a Soil Moisture, Temperature, Humidity sensor. HiGrow communicates with a cloud application for uploading data and the user can check his plants and sensor with an app.It uses ESP32 to powered by lipo battery, a Soil Moisture sensor and a DHT11 Temp and Humidity sensor.HiGrow hardware is almost opensource. We'll publish very soon the instruction to assemble your HiGrow and 3D print the case on http://www.higrow.techYou can find the ongoing firmware udpates, based on Arduino IDE, on GitHub: https://github.com/lucafabbri/higrowopenTo the ones interested in developing apps working with ESP32 we are also doing a porting of ESP TOUCH Smart Config to Xamarin. So you can integrate the libraries in your cross platform pr
#Installation steps
Firmware is based on Mongoose OS platform https://mongoose-os.com/ once you have installed Mongoose OS the HiGrow firmware project is available from the Library
javascript - 3.33 kB - 02/12/2018 at 21:08
Download
markdown - 738.00 bytes - 02/12/2018 at 21:08
Download
yml - 1.48 kB - 02/12/2018 at 21:08
Download
  • 1
    Flash the firmware
    We moved the project to Mongoose OS which has a more stable and flexible library for Bluetooth.
    From Mongoose is really easy to flash your board:
    1. Install Mongoose OS following the instructions here
    2. Connect your device via USB and turn it On (some light should blink :)
    3. Clone the project form library to your dashboard
    4. Build the project and then flash it on the board
  • 2
    Install the app
    app are almost ready, keep you posted
View all instructions
yann R wrote 3 days ago point
Hello Luca, thank you for your work.
That she is the number pin of the sensor ?
to integrate soil moisture into blynk
Thank you
rgarciadelarosa wrote 7 days ago point
Este proyecto sigue vivo ??
alguien lo tiene en marcha
tengo dos tarjetas compradas para poder instalar.
muchas gracias.
fhefter wrote 04/18/2018 at 17:59 point
Hallo Luca,
your github https://github.com/lucafabbri/HiGrow-Arduino-Esp/blob/master/HiGrowEsp32/HiGrowEsp32.ino sketch has a light sensor (pin 33).
This seems to produce random numbers around 90-110 in my case. Where is the light sensor on the board? Is it the multi pin rectangle in the center? I already played with the adc attenuation and resolution but had no luck.
I use the rev1 board with the HiGrow icon.
A circuit diagram would be very helpful. Rev 1 and Rev 2, if possible.
Btw.: I'm also missing the transistor opposite to the "H" of the Icon. What is it for?
Thank you for all your work!
seriousori wrote 04/18/2018 at 17:14 point
Hi
I have mangoose installed on my esp32.
After that, I uploaded your program.
If I access the esp only see this page.
https://www.dropbox.com/s/dg5xm31g47d0xq0/Higrove.png?dl=0
What did I do wrong?
Markus-Rolf wrote 02/18/2018 at 08:30 point
Hi to all,
very nice project this sensor. I would love to test it but I can't get my hardware running because of the header files. Is it possible, that you can also upload the *.h files? I'm not sure where to get them.
Thanks for your help,
Markus
Luca Fabbri wrote 02/12/2018 at 21:10 point
Hi everyone, thanks for your support! If anyone has experience with Mongoose OS you can review the code: any improve would be really appreciated!
Marcus Hoffmann wrote 03/17/2018 at 18:16 point
Hello Luca, is there any Android App available, yet?
Svirik82 wrote 01/03/2018 at 04:09 point
Hi people, I have a problem with your sketch!
Error during compilation. Can tell me what to do?
I took it from here: https://github.com/lucafabbri/higrowopen
Maybe it's in the DHT sensor library.
which library do you use?
The error is this:
C:\Users\HP_DV7\Documents\Arduino\sketch\HiGrowEsp32\HiGrowEsp32.ino: In function 'void setup()':
HiGrowEsp32:50: error: 'esp_deep_sleep_enable_timer_wakeup' was not declared in this scope
   esp_deep_sleep_enable_timer_wakeup(1800 * uS_TO_S_FACTOR);
HiGrowEsp32:51: error: 'esp_deep_sleep_pd_config' was not declared in this scope
   esp_deep_sleep_pd_config(ESP_PD_DOMAIN_RTC_PERIPH, ESP_PD_OPTION_OFF);
C:\Users\HP_DV7\Documents\Arduino\sketch\HiGrowEsp32\HiGrowEsp32.ino: In function 'void loop()':
HiGrowEsp32:75: error: 'esp_deep_sleep_enable_timer_wakeup' was not declared in this scope
   esp_deep_sleep_enable_timer_wakeup(DEEPSLEEP_SECONDS * uS_TO_S_FACTOR);
C:\Users\HP_DV7\Documents\Arduino\sketch\HiGrowEsp32\HiGrowEsp32.ino: In function 'void sensorsData(char*)':
HiGrowEsp32:98: error: 'class DHT' has no member named 'computeHeatIndex'
   float hic = dht.computeHeatIndex(temperature, humidity, false);
We use the library WiFi ver 1.0 from the folder: C:\Users\HP_DV7\Documents\Arduino\hardware\espressif\esp32\libraries\WiFi We use the library HTTPClient ver 1.1from the folder: C:\Users\HP_DV7\Documents\Arduino\hardware\espressif\esp32\libraries\HTTPClient We use the library DHT from the folder: C:\Users\HP_DV7\Documents\Arduino\hardware\espressif\esp32\libraries\DHT (legacy)
We use the library WiFiClientSecure ver 1.0 from the folder: C:\Users\HP_DV7\Documents\Arduino\hardware\espressif\esp32\libraries\WiFiClientSecure exit status 1
We use the library C:\Users\HP_DV7\Documents\Arduino\hardware\espressif\esp32\libraries\BLE: C:\Users\HP_DV7\Documents\Arduino\hardware\espressif\esp32\libraries\BLE
There may be a problem in the DHT library?
Be so kind as to tell me!
If you need a mail: Svirik82@gmail.com
Ice2Cool wrote 01/19/2018 at 22:17 point
Try to include following:
#include "esp_deep_sleep.h"
seriousori wrote 05/01/2018 at 11:52 point
Hello, thank you for the suggestions.
Have it flashed but I'm not on the web server showing the data.
Nothing happens after flashing.
This shows the serial monitor:
ets Jun 8 2016 00:22:57
rst: 0x1 (POWERON_RESET), boot: 0x13 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
rst: 0x10 (RTCWDT_RTC_RESET), boot: 0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP: 0xee
clk_drv: 0x00, q_drv: 0x00, d_drv: 0x00, cs0_drv: 0x00, hd_drv: 0x00, wp_drv: 0x00
mode: DIO, clock div: 1
load: 0x3fff0018, len: 4
load: 0x3fff001c, len: 956
load: 0x40078000, len: 0
load: 0x40078000, len: 13256
entry 0x40078a90
DeviceId: 207537695927856
-1
Luca Fabbri wrote 02/12/2018 at 21:15 point
we moved the development to Mongoose OS, you find the code here https://forum.mongoose-os.com/discussion/2011/new-contribution-higrow-plant-monitoring-sensor
Ice2Cool wrote 01/02/2018 at 16:49 point
Hi, im looking into this project and bought two sets of PCB from aliexpress (this is where I stumbled onto it). Before loading any code to it I discover that my two boards does not have the transistor/FET, the 3 pin SMD component in the bottom part (toward soiltail). Does it exist any electrical drawing to this board so that I can investigate the board and its components?
BR
Ice2Cool
Luca Fabbri wrote 02/12/2018 at 21:12 point
Hi! could you share a pic? the producer made an initial version which was faulty!
eok wrote 11/22/2017 at 18:46 point
is there a voltage divider to monitor the battery?
on which pin is it?
are there any more infos about the board?
which sensor is on which pin?
why is the github sketch not maintained?
Luca Fabbri wrote 02/12/2018 at 21:13 point
Not on thi sversion, rev2 is based on Adafruit schematics using LiPO and voltage divider on pin 13
alandonegan wrote 11/01/2017 at 16:48 point
Hi Luca,  I'd be very interested in purchasing one of your ESP32 dev boards for my project, are they available on any other online stores other than Amazon.it
I posted the cheaper link to Aliexpress (they are almost everywhere just type higrow in your favourite repo)
stefanbode wrote 10/28/2017 at 11:31 point
you will get the PCB with the ESp32 onboard. Batterie 18650 and housing are not included. How’re this helps.
biauwe.de wrote 10/20/2017 at 19:36 point
20 € for what?
