1Flash the firmware
We moved the project to Mongoose OS which has a more stable and flexible library for Bluetooth.
From Mongoose is really easy to flash your board:
- Install Mongoose OS following the instructions here
- Connect your device via USB and turn it On (some light should blink :)
- Clone the project form library to your dashboard
- Build the project and then flash it on the board
2Install the app
app are almost ready, keep you posted
Luca Fabbri
This is a very nice project, but It's a little while since anything happened. Is it still alive? Did you ever post the PCB design files for V1 or V2?
