Jumping on the Bandwagon
A project log for Ye Olde Nowt
Yet another pi zero retro handheld game console.
dehipudeʃhipu 06/22/2017 at 11:420 Comments
Everybody and their dog seem to be making retro handheld consoles out of the pi zero, so I decided it's time to join the party. This one is mostly inspired by the #Pi0CKET-tiny project -- but I didn't have the cool rocker, and I wanted to try a horizontal orientation. I also used an OLED screen in place of a TFT, because of better viewing angles. Oh, and instead of the joystick I used standard buttons. But otherwise it's very similar.
I started by testing the screen. I simply connected it to the SPI port and followed the instructions from #Pi0CKET-tiny about configuring it. Except I used the "pioled" for the display driver name. I stumbled upon the same bug with rotated display, and I solved it in the same way -- when that gets fixed, we can both remove the hacks.
Once I knew the display works, I became confident enough about all the rest to design and order the PCB.
It's basically just the screen connections, the low-pass filters for the speakers, and all the rest of pins are connected to the buttons. And yes, I got a bit wild with the holes. Sue me.
