An Unfortunate SMD Project
If you like happy, easy to build projects, this is not for you. This project is only for people who like to be miserable and frustrated.
Test your surface mount soldering skills out, starting with a 1206 package and work your way down into an oblivion of frustration. Powered by a CR2032 coin cell and Attiny 85 SOIC.Be warned that trying to hand solder a 0201 package, which is just slightly larger than a grain of sand, may be considered evidence of insanity and get you committed to bad places by your loved ones and/or arch nemesis.I have submitted to request from miserable people to make this an unfortunate kit. Don't think I'm doing you any favors: https://www.tindie.com/products/MakersBox/smd-challenge/
Making LEDs blink is what people think make Makers happy, but they are wrong. Makers want to be miserable. They like to make mistakes and to have to try things over and over again. That which does not kill us, makes us stronger. This project will make you strong!
Hand soldering a 1206 is easy and makes me happy, so I decided to see how far down the package sizes I could go before I was reduced to tears. I can do a 0402 package by hand, but it isn't pretty.
My biggest hurdle was determining orientation of the LEDs. You need to refer to the datasheets because each one has different markings. You will also need a USB microscope or really good magnifying glass for the smaller packages.
You are also going to need a good set of tweezers. Robots, who will rule us shortly, have no trouble picking and placing these devices (without error or complaint I might add), but shaky hands and faulty eyes make this a sad affair all around for us miserable mortals. If your luck is as bad as mine, you will spend lots of time frustratedly looking for microscopic dots when they fling out of your tweezers. Buy several extras of each size because the universe will go out of its way to make sure you will need them.
SMD_challenge_Cylon.ino
New firmware that flashes LEDs in a less unfortunate order, like the Cylon Warriors who try and hunt humans into nonexistence in our miserable future.
ino - 1.84 kB - 03/29/2018 at 15:25
Download
SMD_challenge mask.svg
This is the SVG file which can be used to laser cut a mask. Why would I encourage this sad behavior?
svg+xml - 8.36 kB - 07/27/2017 at 04:37
Download
mask-F.Mask.gts
This is the gerber file of the top mask which can be uploaded to OSH Stencils to have a mask made, or if you are unfortunate enough to have a laser laying around the house.
- 1.68 kB - 07/27/2017 at 04:37
Download
A very poor excuse of a schematic for those of you depressed enough to be interested.
Portable Network Graphics (PNG) - 88.86 kB - 06/05/2017 at 03:31
Preview
Download
SMD_challenge.ino
The sad original firmware that blinks LEDs in a very unfortunate random pattern.
ino - 3.41 kB - 06/05/2017 at 03:17
Download
View all 14 components
  • Official Toorcon Badge?
    MakersBox09/16/2018 at 03:01 0 comments
    The SMD Challenge had already spread misery to poor attendees of ToorCamp this year, and no good deed goes un-punished, so I was greatly disheartened when a request for more SMD Challenges for this year's ToorCon became a request to help with the official badge?  Four hundred kits.  Woe is me.
    Luckily for attendees, the SMD Challenge is actually just a small part of this badge.  There are all sorts of codes in all sorts of places.  I'm not sure what they all mean, or what you get if you figure them out.  I was sworn to secrecy, had my eyes gouged out, and was forced to burn all my gerber files.  I'm not responsible for the beautiful 8-bit art (obviously, because it is not miserable), nor do I know what "Toor" and heart cats have in common.
    This SMD Challenge is more miserable than other because it features eight, not six, SMD LEDs.  It is only by my distaste of handing the smaller parts (and their greater expense), that only one of the LEDs is of the 0201 variety.  Why eight?  Sworn to secrecy.
    Ironically, the beautiful artwork made identify component placement a bit ugly.  I'm also not sure what bit of insanity made me switch LED orientation based on what side of the heart the part was.  I'm obviously not doing anyone any favors, but here is a clear PCB screenshot, sans artwork and secrets, showing size and orientation.
    If you are struggling to even get started on this, Piotr Esden-Tempski has done an excellent video.  One hint for the initiated:  Get the Attiny in the right orientation, or it will go up in smoke.  Wait, that is the Attiny85.  This one used a more forgiving Attiny84, so it will be just a non-functioning piece of 8-bit art.
    If you are heartless enough to want to include some misery in your next event, please don't contact me.  Because apparently I can't say no.
  • Apparently competitive soldering is a "thing" now.
    MakersBox08/30/2018 at 21:59 0 comments
    Don't blame me.  I just wanted so see what small SMD parts looked like up close.
    Tindie, who I sell my kits through, contacted me about some custom kits for DEFCON, and I was eager to see the board in different colors.  I think they turned out nice:
    I kitted 100 of each.  DEFCON turned it into a contest with a time limit and scoring system.  I'm sure I wouldn't score in the top group, but it sounds like it was a success.
    The winners of the soldering challenge, at the Hackaday Breakfast Meetup at DEF CON 26.
  • Outdoor Misery
    MakersBox07/01/2018 at 18:33 0 comments
    Will C. (@WillCaruana), who I met at Teardown, decided to spread the misery to the great outdoors, more specificly ToorCamp.  And what to do we do when we are miserable?  Drink?  Will reported:
    The Toorcamp SMD Challenge was free form competition. There was no order that needed to follow for soldering on components. Attendees didn't learn about the challenge until they arrived on the island. They were welcome to use any gear they wanted (Though every one is camping so they didn't bring much.) The camp did supply soldering irons and flux on a first come first serve basis. One person did end up bring a hot air station. We had about 20 contestants all of them sharing equipment. Everyone was given 6 beers you had to finish one beer before you could solder the next two components. Bunny won completing the board in 1 hour and 2 minutes literally crushing his beers along the way.
    I believe Bunnie (@bunniestudios) is now the most prominent member of the 0201 Club. He was, incidentally, the keynote at Teardown, where he talked about his current project and his lawsuit to reform the DMCA.
    You can see the special edition ToorCamp Challenge pinned to the wrist of his sweater.  Now why doesn't he look miserable?
  • An Unmiserable Artist
    MakersBox04/08/2018 at 16:02 0 comments
    This person is an artist.  And flux is your friend . . .
  • Can it get any more miserable? Yes.
    MakersBox03/31/2018 at 12:13 1 comment
    I originally didn't think that hand soldering a 0201 component was possible.  Several dozen people have proved me wrong.  Can I make their life more miserable?  Enter the "01005" package:
    Yes, that is a ball-point pen tip. And yes, it is hard to get good photographs of things this small.
    The Misery Edition of the SMD Challenge now includes a Attiny84 QFN20 package and a 01005 size resistor.  Since I haven't found a matching LED for it yet, I added another 0201 LED, but being a heartless and cruel man, I selected a diffuse one so you can't determine orientation visually (assuming you even have magnification available).
    I am not totally devoid of feeling, so I have designed it so that a backward LED will still light, but you will be denied the joy of witnessing the full terror of the Cylon sequence.  As a further enticement, I've included a power switch to save battery life.
    Green 0402 LED Reversed
    I assume you miserable people will want to celebrate your successful struggle, so there will be a 01005 Club, but don't think you can be the first, because some sorrowful sole found my evil designs on Github and made one on their own.  Truly depressing.
    You can induce your misery straight from source here: https://github.com/aspro648/KiCad/tree/master/projects/Attiny/AttinyChallengeMisery, or just buy a kit of pain on Tindie here: https://www.tindie.com/products/MakersBox/smd-challenge/ (select "Misery Edition").  It would save the terror of trying to flash an Attiny and help me pay off the $80 programming socket I needed to preload the firmware.
  • 0201 Club
    MakersBox12/25/2017 at 06:42 4 comments
    As the misery spreads, it seems only fitting that we should recognize those who are unfortunate enough to suddenly complete the SMD Challenge.  To be included in this club, you must submit photographic evidence (or link thereof) of a working SMD Challenge to 648.ken@gmail.com, for which you will receive inclusion on this list and a digital copy of a frame-worthy certificate of your skill and/or insanity.
    Members:
  • A Miserable Competion
    MakersBox12/07/2017 at 05:58 0 comments
    I don't know how this keeps happening, but the misery spreads despite all my warnings.  The latest victims include four hands from SparkFun.  You think they would have known better:
    https://www.facebook.com/SparkFun/videos/10156329586911416/
    What I learned from watching the pros at work:
    •  I used the stock KiCad 0201 footprint (which I may or may not have verified against the data sheet).  This is appropriately inappropriate for hand soldering.
    • You don't need the data sheet if you test your components.
    • Speed is good, but attention to detail is King.
    • There is far less swearing at SparkFun than at my workplace.
    •  I've got to get me a loop!
    • My chance at getting hired on at SparkFun may have significantly decreased.
  • Lousy Firmware Update
    MakersBox11/05/2017 at 21:33 1 comment
    This project shared firmware with the much less miserable I Can Surface Mount Solder one.  Both projects have a 1206 LED that flashed with a heartbeat.  On the SMD Challenge, the additional LEDs blinked randomly.
    Thinking it would be more frustrating to have it quite obvious when you invariably mess up an LED, I decided to have them flash in sequence, much like the cold and heartless Cylon Centurions
    If you want to learn more about how sadly slow our eyes are compared to computers, check out http://www.makersbox.us/2013/12/arduino-beyond-blink-how-fast-is-fast.html.
    Unfortunately, I had to make another set of kits.  There must be a lot of miserable, frustrated hobbyist out their willing to pay for some woe.  The PCBs came in groups of four with an boring star-shapped cut out in the middle.  I promptly punctured my finger on one, so if there is blood on your kit, know that I share your pain.
    I should have left the mouse-bite edges on there to punish you further, but decided to coat my table and lungs with fibreglass to add to my own misery.  You are welcome.
  • Influencing Digkey Search Results?
    MakersBox10/17/2017 at 04:28 1 comment
    An Unfortunate SMD Challenge Participant Reported:
    On DigiKey, when I was searching for the 754-2022-1-ND (the 0201 LED), I
    noticed that in the "you might be interested in" results from DigiKey,
    they listed:
        BAT-HLD-001 - Linx Technologies Inc. | BAT-HLD-001-ND DigiKey
        Electronics
        BAT-HLD-001
        HOLDER BATTERY 20MM COIN
        Unit Price 0.28000
        BAT-HLD-001-ND
        ATTINY85V-10SUR - Microchip Technology | ATTINY85V-10SURCT-ND
        DigiKey Electronics
        ATTINY85V-10SUR
        IC MCU 8BIT 8KB FLASH 8SOIC
        Unit Price 1.25000
    So it would seem that the SMD Challenge orders have affected the DigiKey
    search results...  though, who else would be ordering 0201 LEDs, right?
    LOL
  • It Can Be Done!
    MakersBox09/13/2017 at 04:59 7 comments
    I wouldn't believe it if I hadn't seen it my self.  Hand soldering a 0201.  A miserable young whelp of an Electronics Technician.  Proved me wrong.  Photographic proof submitted to boot:
    He did use a microscope.  And a JBC station with a 0.2mm tip.  But still, it can be done.  Misery upon us all who don't have young eyes and steady hands.
    I've been thinking about scoring.
      + 50 points for attempting this project (or being foolish).
      + 10 points for getting one LED to blink (you got the Attiny in correctly and can tell the polarity of an LED).
      + 5 for the 0805 lighting up (Give me a break, it is not much smaller than a 1206).
      + 10 for the 0603 (so you have an unfortunate set of tweezers on hand).
      + 10 for the 0402 (alright, we getting serious up in here).
      + 15 for the 0201 (you got lucky, punk).
      - 5 for using a microscope unless you are over 50.
      - 10 for using a paste and a mask (hey it works, but you cheated).
    By this method, my young unfortunate friend scored a 95.
    And I have scored an 85 and 90.  Yes, I used a mask, but I need to prove the circuit and code worked, right?
    So, to break the record, submit miserable proof of all LEDs blinking, without a mask, and without a microscope, unless you are unfortunate to be over 50 years of age.
View all 14 project logs
  • 1
    Step 1
    You should not build this. It is impossible to complete, so why bother. The picture is probably photoshoped to show it working, as is this video:
  • 2
    Step 2
    If you want pain in your life, do not read the datasheets. They contain very sad information. The pictures are also miserable. You have a 50-50 chance of getting the alignment right, so why even try?
  • 3
    Step 3
    Soldering by hand is impossible, so don't even try. It will only make you rant. It is unlikely that this video will help either:
View all 4 instructions
mwahid wrote 06/05/2017 at 06:27 point
Cool project :)
oshpark wrote 06/05/2017 at 05:08 point
clever idea! looks fun :)
