first step was to simply connect the DCF77 receive modul to a arduino and see if I get those 0 and 1 bits received.
I used this code:
#define DCF77PIN 2
unsigned char signal = 0;
unsigned char buffer;
void setup(void) {
Serial.begin(9600);
pinMode(DCF77PIN, INPUT);
void loop(void) {
signal = digitalRead(DCF77PIN);
if (buffer != signal) {
Serial.println(signal);
buffer = signal;
after searching a better position for the antenna (don't place it near the computer), I got the 1-0-1-0-1-0 response on the serial monitor. Fine
mclien
