receive test
A project log for Smart DCF77 Wirst Watch
A retro style Wirst Watch with a LED segment Display. Receiving time over DCF77 and personal reminders over a hacked/modified DCF77 signal.
mclienmclien 08/18/2014 at 18:580 Comments
first step was to simply connect the DCF77 receive modul to a arduino and see if I get those 0 and 1 bits received.
I used this code:
#define DCF77PIN 2
unsigned char signal = 0;
unsigned char buffer;
void setup(void) {
  Serial.begin(9600);
  pinMode(DCF77PIN, INPUT);
void loop(void) {
  signal = digitalRead(DCF77PIN);
  if (buffer != signal) {
  Serial.println(signal);
  buffer = signal;
after searching a better position for the antenna (don't place it near the computer), I got the 1-0-1-0-1-0  response on the serial monitor. Fine
