<a href="http://Hackaday.io" target="_blank">Hackaday.io</a> uses the Redactor editor which isn't like the standard forum editors you may be used to. In those editors you can usually use *imagine missing greater-than and less-than symbols* to make text bold etc. Redaction breaks out those features into buttons but one I want is missing: strikethrough. It's useful for indicating an error was made or for signalling humour.
This project documents a (currently) working way around the missing button.
Open up your editing window by adding a project log or instructions etc.
2
Step 2
Write your post, either until you get to the point you want to add strikethrough text or the whole thing.
We can do all the strikethrough at the end.
3
Step 3
Now click the <> button at the top of your editing box. If your draft post disappears, don't worry (yet) - scroll up to see if it has been turned into plain text at the top.
Disclaimer - I use imgur to link my images in, so I don't know what effect this has on other methods of inserting images
