Design requirements
A project log for GSM-connected remote electric gate
Allows a user to open and close an electric gate by making a simple phone call
bredmanbredman 06/06/2017 at 12:410 Comments
The operation should be very robust.
The operation should be very predictable.
The system should be easy to maintain.
The system should use whatever electrical power is available.
The system must recover gracefully from a power failure.
The system must recover gracefully from a GSM network disconnection.
The PCB should be as small as possible, because space may be limited in the box for the gate electrics.
