Discovering the Demands
A project log for AVR Parallel Programming Testbed
Batch Testing and Programming PCBs
andre-moehlAndre Moehl 06/06/2017 at 11:300 Comments
When I start the development, I needed to consider the demands for testing and programming. We had two different kind of PCBs which need to be tested and programmed. They had only the programming interface in common, ISP.
What I need to test:
USB means here, that one PCB can be an USB Device, that makes a USB Host functionality necessary.
Our panels are designed for 20 PCBs. They all should be tested and Programmed as fast as possible. We need a system which makes all parallel.
Other Requirements:
All together I needed 3-4 month with the development.
