Talk through design iterations
A project log for 6-Axis Micro Manipulator
Micron level manipulator, using printed and low cost components
david-brownDavid Brown • 10/13/2017 at 17:58•0 Comments
As I needed to put together a video, which ended being longer than required so I'm posting it here. This is a talk through of the different design iterations and how I ended up with the current design, including comment of limitations and areas that could do with further work.
I do think the original concept could work but requires the right size stepper motor with integral lead screw to be available.
