First fail
A project log for Epaper Display Badge
A mini EPD badge with bluetooth LE and SD card for standalone display
Thomas GonnotThomas Gonnot 07/03/2017 at 18:080 Comments
So I received all the components, and used my reflow over (toaster) to solder all of them. Unfortunately some shorts appeared, and in the effort to fix it, I overheated the ePaper connector. Everything works fine except I can't connect the display...
Will get another batch of components and try again later in the month.
