The easiest is done!
A project log for Internet of Beds
IoB is a Bluetooth Low Energy weight sensor, placed under your bed, that force you to get-up in order to stop your alarm clock!
mdresfmdresf 06/07/2017 at 16:390 Comments
I just finished the hardware assembly and the arduino code. I am know able to published the measured value via Bluetooth Low Energy. I checked the system using "nRF Connect" application. That was the easy part.
Know I need to create an android application ( this is my first time!). I managed to found an open source alarm clock that may fit my needs: https://github.com/SheldonNeilson/Android-Alarm-Clock
But I am still hesitating to start from scratch...
