Populating the PCBs
A project log for SLoRa - Wireless weather station for agriculture
Low power, Long range wireless weather sensor system to detect potential frosting and alert the farmer to take action.
dorijanDorijan 06/12/2017 at 06:330 Comments
Since the module is in QFN package, without any exposed leads the only sensible way was to populate the boards using solder stencil and reflow owen.
Therefore when I ordered PCBs from PCBway I also purchased framed stencil which consisted of all the boards I have ordered.
The module has quite a decent spacing between pins which makes it easy to be populated without any shorts. I managed to successfully run all 5 out if 5 boards.
The sensor sticks worked in the first iteration. But ESP replacement modules require a small connection to be made to rf_vdd.
For programming a footprint for tag connect is used.
Image: Mostly populated boards prepared for the reflow owen
