The HealthyPi can also work with a PC
A project log for Connected Health: Open source IoT patient monitor
This project describes the use of Raspberry Pi as an IoT connected vital signs monitor. The HealthyPi HAT for Raspberry Pi used.
Ashwin K WhitchurchAshwin K Whitchurch 06/24/2017 at 06:050 Comments
Did you know that the HealthyPi board can be used by itself, without a Raspberry Pi? This allows for connection to a PC through USB. You can even use the UART pin on the header to directly connect to your own system or any other board. Beagleboard anyone??
We'd love to see what other board or platform you can integrate HealthyPi with? For more information about this, check out our update on ourCrowd Supply campaign page.
https://www.crowdsupply.com/protocentral/healthypi-v3/updates/using-healthypi-v3-in-usb-mode-with-a-pc
