Sabots_for_PCBs.zip
STL files for PCB "sabots". Print with .2 mm layer height.
x-zip-compressed - 71.25 kB - 12/24/2017 at 04:04
Download
sketch_keyjoy_mark4.ino
Software sketch. Compile with Arduino IDE.
ino - 27.93 kB - 12/24/2017 at 04:01
Download
03.zip
Thumb PCB files
x-zip-compressed - 9.71 kB - 12/18/2017 at 22:27
Download
02.zip
Left PCB files
x-zip-compressed - 8.13 kB - 12/18/2017 at 22:26
Download
01.zip
Right PCB files.
x-zip-compressed - 11.85 kB - 12/18/2017 at 22:26
Download
08_Right_Keys_and_Wrist_Combined.stl
Combined parts 02 and 04 for printers with bed larger than 170x170 mm.<br>Step 0.2 mm, support from plate only, top/bottom 1.6 mm, wall 1.2 mm, infill 25% - 17.5 hrs print time.
Standard Tesselated Geometry - 677.57 kB - 08/13/2017 at 02:38
Download
07_Left_Keys_and_Wrist_Combined.stl
Combined parts 01 and 03 for printers with bed larger than 170x170 mm.<br>Step 0.2 mm, support from plate only, top/bottom 1.6 mm, wall 1.2 mm, infill 25% - 17.5 hrs print time. Saving over printing parts 1 and 3 separately is about 1 hour.
Standard Tesselated Geometry - 677.57 kB - 08/13/2017 at 02:33
Download
06_Thumb_Button_Stand.stl
Stand for thumb keys<br>Step 0.2 mm, no support, top/bottom 1.6 mm, wall 1.2 mm, infill 50% - 1.8 hrs.
Standard Tesselated Geometry - 62.68 kB - 08/13/2017 at 02:33
Download
05_Joystick_Stand.stl
Joystick stand (print twice = 1.3 hr)<br>Step 0.2 mm, no support, top/bottom 1.6 mm, wall 1.2 mm, infill 50%.
Standard Tesselated Geometry - 82.21 kB - 08/13/2017 at 02:32
Download
04_Wrist_Support_Right.stl
Wrist Support Body (right hand)<br>Step 0.2 mm, support from plate only, top/bottom 1.6 mm, wall 1.2 mm, infill 25% - 9.5 hrs print time.
Standard Tesselated Geometry - 562.19 kB - 08/13/2017 at 02:31
Download
03_Wrist_Support_Left.stl
Wrist Support Body (left hand)<br>Step 0.2 mm, support from plate only, top/bottom 1.6 mm, wall 1.2 mm, infill 25% - 9.5 hrs print time.
Standard Tesselated Geometry - 562.19 kB - 08/13/2017 at 02:30
Download
02_Keys_Body_Right.stl
Key Holder Body (right hand)<br>Step 0.2 mm, support from plate only, top/bottom 1.6 mm, wall 1.2 mm, infill 25% - 8.5 hrs print time.
Standard Tesselated Geometry - 153.06 kB - 08/13/2017 at 02:29
Download
01_Keys_Body_Left.stl
Key Holder Body (left hand)<br>Step 0.2 mm, support from plate only, top/bottom 1.6 mm, wall 1.2 mm, infill 25% - 8.5 hrs print time.<br>Step 0.1 mm for fine finish - 17 hrs.
Standard Tesselated Geometry - 153.06 kB - 08/13/2017 at 02:27
Download
Joystick_Cap.stl
Joystick button (print twice)<br>Step 0.1 mm, support from plate only
Standard Tesselated Geometry - 700.47 kB - 06/10/2017 at 09:40
Download
Thumb_3.stl
Thumb button 3<br>Step 0.1 mm, support from plate only
Standard Tesselated Geometry - 14.54 kB - 06/10/2017 at 09:40
Download
Thumb_2.stl
Thumb button 2<br>Step 0.1 mm, support from plate only
Download
Thumb_1.stl
Thumb button 1 (print twice)<br>Step 0.1 mm, support from plate only
Download
Stems_x6.stl
Stems for buttons<br>Step 0.1 mm, no support
Standard Tesselated Geometry - 23.52 kB - 06/10/2017 at 09:40
Download
